I'm trying to fit an outside tap and have purchased a kit from Amazon.
Being a complete amateur, I failed to measure up correctly! The thru wall flange is slightly (1cm) too short, so I guess I would need to purchase a longer one. Also, my water pipe (under the sink) is approximately 1.5 metres from where the thru wall flange enters. The kit I have uses 300mm 1/2BSP to 15mm Push Fit flexi connector. Is there any way I can easily extend this connector? I can't seem to find anything that is long enough to do the job. Thanks in advance!
