As above if it’s for a standard garden tap domestic installation yes, as above, on new installations, it’s a requirement to be located internally. If it’s a replacement, then only where impractical to fit internally, can you replace with the tap type. If there’s going to be the use of fertiliser or it’s near a bin store, then speak to your local water undertakers regulations department, as these are whom enforce the regulations.
