Outside tap internal DCV
18 Mar 2018
Does anyone one use a combined isolation and DCV for an outside tap installation. Instead of and isolation and separate DCV. Thanks
A filling loop isolator with the double check valve instead of a isolation valve and a double check valve?
I haven't, but I think a filling loop isolator may cause a restriction, that could be detrimental to the flow rate of an outdoor tap.
I personally, have full bore isolators and a 22mm DCV and am very happy with the performance of the tap.
