I have no water coming out of my outside tap. The tap itself is fine and there is a quick trickle when turning on. I don't know if it's down to a pump I had installed for better water pressure downstairs, could this cause it? I can't get hold of plumbers that installed it and can't find valve to see if it's been turned off and not turned on again by them. Would a pump cause this?
