For some reason the outside tap at my house is plumbed into the hot water supply and I want to plumb it into the cold.
I have had a look where the tap is spurred off from on the hot water pipe and right below it is a cold water pipe so is it just a simple job of turning the water off, taking the T join out of the hot one, cutting the cold water pipe and putting it in there and then putting a straight through join in the hot water pipe or have I got more to think about ie is air getting into the system going to cause problems?
Just in case it matters I've got a combi boiler.
Thanks,
Dan
Thanks,
Dan
