I have a tricky install to do in my bathroom where I have a couple of tap isolation valves that required a female 1/2" BSP union to screw into (female 1/2" BSP union needs to be set inside wall).
The tap isolation valve does not have enough thread to make it through the wall (12.5mm board plus 10mm tiles and tile adhesive) into a standard tap elbow backplate so I am looking for alternative solutions.
Found this at screwfix:
http://www.screwfix.com/p/hose-union-back-plate/56415
Looks ideal. Easy to solder onto the 15mm pipe and easy to mount the flange on the inside of the wall (I have easy access to that side). Plus, female union extends 25mm beyond the flange so is perfect to screw into from the tiles side of the wall.
Sorted right? Bought a couple from screwfix and they are covered in warning stickers that say they are for external/garden use only.
'For Garden Use Only'
'This product is designed for use with hose union bibcocks only'
Could this just be some British Standards thing or can anyone think of a practical reason whyt this approach is not advisable?
Thanks,
iep
Thanks,
iep
