- Joined
- 14 Apr 2005
- Messages
- 31
- Reaction score
- 0
- Country
nstreet said:Sounds like you got a bit carried away to me.
The Screwfix kit is idiot proof
Slugbabydotcom said:The Screwfix kit is idiot proof
Maybe but I have come across quite a few where the bit of pipe thats cut out to make the hole comes away cos the steel cutting bits rusts through gets stuck in the tap and badly reduces the flow or drops down to a tee piece runs along the pipe and causes havoc elsewhere.
Fit em if u like! but I dont cos to me they are not proper plumbing.
Does that include non-return valve and insulation?jimdoodson said:No I advertise to fit outside taps complete with an internal stop cock for £50 .00 ,quite a good earner.
In an out in 20 min
... or maybe as you've only used them recently the problems haven't happened yet. Personally if I was employing a plumber for this kind of job I'd expect to see the job done right, not just a DIY bodge.jimdoodson said:Had no problem with flow or the cutter rusting. Maybe the ones I use have been inproved.
