Outside Wall Light
13 Jan 2007
Gloucestershire
Help or advice please.
I have an outside wall light. Lately in the cold weather, I have to change the light bulb every couple of days.
Is this due to cold weather or does the light fitting need replacing?
All the wiring is concealed and as far as I can see, not prone to the elements.
Thanks in advance
If it's a CFL it may give the appearance of having failed when what's wrong is that it's too cold for it to start.
If you have been merrily replacing CFLs, do you still have any of the ones you've taken out? (I hope so, because you're not allowed to just chuck them in the bin).
Thanks for the replies.
The first couple of bulbs were the old 40W type. The next one to go was an energy saving type, (10W=60W).
Thanks again
Strange because the weather isn't really that cold now. I was going to suggest maybe the 40w was overheating in the fitting if it was designed for energy savers but if your 10w CFL isn't lasting then not too sure.
High supply voltage maybe? But why suddenly a problem now and I don't think that would cause a problem for the 40w lamp?
Sorry more questions than answers. :oops:
