I have a 6kw hob and 3.2kw oven that I would like to connect to an existing 6mm cable (which is currently protected by a 40A MCB). The installation guides say to use 2.5mm cable for the hob and 1.5mm cable for the oven. How do I do this?
For the oven you'll be able to use 1.5mm² because it'll be plugged in.That's what I originally planned to do - but the installation instructions say to use 1.5mm cable for the oven and 2.5mm for the hob. I was getting confused as to how I could go down from 6mm to these cable sizes and still protect the cables with suitably rated fuses.
Complain to Admin.Sems to have gone a bit off-topic here
Oven cable is fine - hob one is right on the limit at full load current, but it won't draw that for long (if ever) - guess the maker has done his homework on the likelihood of short duration overloads.The cable specified is H05VV-F 3 x 2.5mm for the hob and 1.5mm for the oven
The suggestion was to use the cooker outlet to supply a socket to plug the oven into, not to plug it into an existing socket. It's the former which would be notifiable (new socket), not the latter.Ideally I don't want to put the oven on the existing kitchen ring as I've had that signed off by building control and don't want to go through the whole testing and inspection process again for that circuit.
Oven yes, by installing a socket on the cooker circuit.Unless it can't be done safely, I'd like to connect both the hob and oven to the existing 6mm cable that is currently protected by a 40A MCB (which holmslaw says is ok). Is this possible? Thanks
