I currently have an oven on a dedicated 32A radial circuit with 6mm cabling.
The cable runs from the CU to a junction box, and then to the cooker switch (then 6mm onto the connection unit). The reason that there is a junction box is because somebody had previously spurred off a single switch (now disconnected).
I wish to add an induction hob.
The oven is rated at 4.9kW and the hob 7.4kW, and I have previously been advised that the circuit would be sufficient (up to 15kW total).
I just wanted to check that the fact that the circuit is radial doesn't affect its suitability for that load.
Also, the cable that currently runs from the CU to the junction box, is long enough that it could run direct to the oven socket. Given that, should I run the cable to the oven switch and then carry it on and terminate it at the hob switch (A) , or should I spur the hob from the junction box (B). (A) is certainly better for maintenance, but I just want to check that there are no other considerations.
Any thoughts would be much appreciated.
