Oven and Hob
22 Apr 2005
Cumberland
I have just bought a built under oven with separate hob to replace the existing oven we have. There is a 45amp double pole switch used to feed the existing oven via a connector box. When installing the 2 new appliances do I simply connect both feeds to the connector box?
depends on rating, it would't surprise me if your oven can be plugged into a normal socket
If the oven is 3Kw or less, you can plug it into a normal socket or use an FCU to connect it by itself. Above this, it should be wired with the hob to the outlet plate
