Oven Door doesn't close properly Stoves 900DF
17 Oct 2008
Yorkshire
The oven door on my Stoves 900DFa doesn't close properly , which means that heat escapes and warms up the rest of the appliance!!
I have done some research and believe that the oven door hinges need replaced.
has anyone changed these before on this appliance that could give me some pointers or is there a manual anywhere that i could look at.
Thanks in advance
Fraser
Thanks in advance
Fraser
I think all the hinges on this type of cooker wear in time (three years) and allow the doors to drop quickly and sometimes too far meaning the glass may slide out.
I have an 907mf with other issues although the hinges are a nuisance too.
//www.diynot.com/forums/viewtopic.php?p=1550158#1550158
go to you tube and type in cooker hinges shows how to do it.
Thanks in advance
Fraser
Do you have any problems with the heat when you use the grill(door fully down) cos my stoves oven cuts out bcos it gets that hot wen i use the grill
Answer - don't buy Stoves! I no longer do.
Thanks in advance
Fraser
