My Jackson oven door is not opening fully. Has been fine up until today. After cooking, the door then would only partly open (luckily I was able to get the pizza out!) It's a door that you pull up and down rather than side to side. Is it the hinges?
Could be the hinges but if it is an oven with a glass door I would first look at the bottom edge to see if it is catching, sometimes the adhesive that holds the glass on fails and allows the bottom edge to move and catch.
The door rollers could be worn as well but as you have not posted a model number we can not be definate what type of hinge or fittings you have.
