hi all i was wondering if anyone could help/advise me.
we moved into our current house 6 months ago. the oven was a fitted electric single oven with grill and we had a fitted gas hob. the oven was shot away as was the hob and so i decided to do away with both and get a free standing electric oven with hob.
the last oven was connected to a unit on the wall directly with a switch and a 13 amp fuse.
i had an electrition/gas man in to dissconect my gas hob and he commented that all my power points for the whole hous ewas actually only ran off a 30 amp fuse at the mains. he then told me that if i wanted to run my new oven it would need its own supply from a new fuse at the mains and a new unit on the wall with a thikicer wire going to it.
he then said that really with everythign runnign off the one fuse i was likely to get power surges if i was to run too much in the house at the same time.
my hole hous eonly has 3 fuses. a 5amp for all the lights a 30 amp for every power point and a 40 amp for an electric shower.
i have one more spcae left it is an old box.
what i was wondering is why was the last oven able to run from the unit on the mains with no problems and my new oven not able to be connected the same way.
he said what he said with out even knwoing what wattage my new oven would be.
all i can make out about the rating of my new oven is that it says 230v and 6.85kw. it also says it needs to be connected to a CU with a min of a 32 amo fuse. would i be able to get away with replacing the 30 amp in my box with a 40amp and connecting the oven to the same unit the last one was on?
or is this going to be a rewire job?
