oven / range next to drawers
8 Oct 2008
Tyne and Wear
hopefully someone can help with this, i've been planning a kitchen using ikeas tool. i have a range that i want at the end of a new counter / cupboards but the tool says i shouldn't put drawers next to an oven or range but it says a cupboard is fine. any idea why ? or should i be able to do this ok ? had a guy out to do a kitchen planning session before i gave up with them and he had planned a set of drawers next tothe range
thanks for the advise or info
rob
no idea why .
You go by the manufactures instructions for both range and units. If one says OK and the other says No, the answer is No, you can't, but I can't see the problem unless the drawers are plastic. Perhaps that is the reason.
no idea why .
Yep, that's what I was thinking lagman (Plastic). Can't think of anything else... unless as lifesagasman says, the MIs state you cannot place next to draws/range.
Could be something to do with the Swedish having different safety standards? Maybe they think that you're more likely to snag oven gloves on a drawer (with a hot thing in your hands) than a cupboard, or more likely to splash hot oils into an open drawer?
Who knows?
no idea why .
Unless your storing Novembers fireworks in the drawer....and your partial to the odd flambe....????????????? :eek:
Yep it's confusing.... almost as confusing as the reason why the Mods decided to move this to the Carpentry section! I've often seen chippys installing Ovens/Ranges! :rolleyes:
I have never heard of a reason for not having a drawer unit next to a range/ oven.
