I've got a Belling dual fuel range cooker that is about 10 years old and was installed when the house was new. About a week ago, while the main oven was on, the house's main RCD switch tripped. On resetting the trip, the main oven would no longer heat up, leading me to believe that the element needed replacing. (This happened once before a few years ago and replacing the element solved the problem that time.)
However, during the last few days the RCD has tripped several times whilst using both the side oven and the grill (although not every time we use these). It has also tripped when I plugged another item (the vacuum cleaner) into the socket attached to the cooker isolation switch.
I wondered if there was a problem with the isolation switch so I have now replaced this, but the RCD has tripped again since whilst using both the side oven, the grill and the socket (though only when the isolation switch is on; it has never tripped with the switch off).
Incidentally, when the RCD trips, it always seems to trip the main RCD switch, rather than just the oven circuit.
I'm unsure whether I should:
a) replace the main element and see if that solves the problem (although I'm a bit reluctant to do that if there might be another problem that will cause the new element to die straight away!)
b) Get an appliance engineer in to check the oven.
c) Get an electrician in to check the wiring in the house.
d) Replace the oven completely (I've never particularly liked it and would love to get something better, so I'm reluctant to spend too much on trying to fix it)
e) Or is there anything else I could check myself (I'm OK at simple electrical jobs but wouldn't be confident doing anything major!)
Thanks in advance
Thanks in advance
