Hi there, I am installing a seperate supply for my oven (rated at 2230W) and gas hob. From a 15A fuse it will be wired in 2.5mm twin and earth to a 45A cooker switch (i believe this is ok), my problem is where it goes from there. Here are the options I think I have.
1) both oven and hob hard wired into the switch.
2) oven and hob wired to FCU with 13A and 3A fuses respectively, then wired to switch.
3) Oven wired to an "oven type outlet plate" and hob to a FCU, both then wired to switch.
4) Switch wired to a double plug socket, hob and oven plugged in to this.
What options are legal and what one would be the best, many thanks.
