Seeking ideas.... System is a Viessmann Vitodens 100-W WB1B regularly serviced. Boiler, pressurised to 1bar when cold, filling loop is always disconnected. This provides hot water (no problems) and heating is via a single output in 22mm and T's into two two port valves, one serves downstairs UFH via a Watts manifold and actuators....all working correctly. Both 2 port valves checked and working correctly. When the UFH is calling for heat boiler provides and pressure increases between 1bar to around 1.5bar. If the CH is called for independently pressure increases over 2.5 bar as system heats up and I turn off prior to 3bar. If UFH calls for heat system is fine as described but if CH then calls for heat same thing happens, turn off thermostat for CH and pressure returns to Norman after a period of time. Radiators balanced as best I know how......any ideas gents and ladies
System has a Fernox FI filter which remains very clear and system has been flushed a few months ago
