Hello
I'm about to embark on an expensive journey into roof insulation, if anyone has experience relevant to the following scenario, I will be really appreciative.
I have an c1806 watermill which has two unconverted floors and an uninsulated roof so it acts like a heat chimney, hence the roof insulation issue. I have decided to go with over rafting insulation because the roof needs to be re-laid entirely anyway. My questions are based using multifoils for this purpose, such as Trioso Super 10, and to insulate between the two floors with Thermafleece or similar e-friendly stuff. This will get us closer to a decent overall U value. (If you are wondering why I'm not considering under rafter insulation it is because there are nice sarking boards, oak rafters and purlins which I want to keep exposed, it will keep the conservation dept. happy too).
So, here are the questions. What is the absolute minimum that I can raise the line of the roof to? Some say that I will need an air gap plus battens as well as the insulation which may raise the roof by 100mm, others say that I don't need a gap so the difference will be minimal. Does any one have a view on the product, the application and the roof height issue. (Obviously I want to change as little as possible).
Thanks in advance.
Thanks in advance.
