Today, I was connecting two pipes for a kitchen sink using a isolation valve. At the end of it when testing the pipes I looked and on top of both isolation valves there was a little bubble of water, so naturally i tried tightening them more and the bubble didnt stop (i did dry it beforehand)
I came to the conclusion that I have overtightened the joints. I had done alot of tightening both hands and spanner.
Would i be able to use the same isolation valve, but just change the olive, or would i have de-threaded it?
So the question is, what is the recomended way of tightening the compression joint?
I did hear after, that it is to do it hand tight and then a quater turn, is this correct?
I am considering putting a speedfit connection in, as the water connection to the tap is in plastic ( I did have the insert for compression fittings in the plastic end)
What would be the better way to do it, compression or plastic?
