Hello
I am internally insulating my full-width dormer. I intend to do this with Thermaline or similar - 50mm PIR insulation laminated to plasterboard. £50 a sheet
Currently the dormer face is (from inside to outside) 1/2 inch plasterboard, 2x3 studs with fibreglass in between, DPM, and PVC cladding.
To save some cash I was going to overboard myself and then get them skimmed - is this best or would a plasterer prefer to do the lot? I'm guessing they wouldn't sort the window boards or extend the radiator piping!
bsr
- Would you overboard or remove the old plasterboard?
- Is it easiest to remove the old window boards and fit new?
- How do I detail around the window reveals?
- Would you fix with 100mm plasterboard screws, tape and skim?
- Any other tips?
bsr
