Hi folks,
I'm experiencing an intermittent fault in the 13a socket ring in my garage.
From time to time, when you're using any appliance, it will trip the B30 breaker in the garage's consumer unit. Occasionally, say 1 time in 3, it will also trip the upstream B40 breaker in the house's consumer unit. It never trips the RCDs.
If you reset the circuit breaker it will be fine for another hour or more... sometimes several hours... but it never trips again straight away.
I've tried unplugging every single item in the garage, and only using one thing at a time, and the problem still occurs so that has eliminated appliances as being the issue.
The problem only occurs when you're using something - so if I leave the garage for days on end it will not trip by itself, but if I go in and plug in a 750w heater or a 500w power tool it will likely trip once every hour or two.
Could do with a steer on how to approach finding the fault.
My best guess is it must be damaged wire/insulation somewhere which is allowing a short circuit when the wire heats up? But the wiring is only 3 years old and fully trunked/protected all round. I've checked for any obvious signs of damage but can't find any.
I've inspected inside the CU and no signs of problems in there, and I've checked a few of the sockets which I thought may have got dust in them, but they were totally clean and no signs of problems.
Would appreciate any advice.
Cheers,
Rich
Cheers,
Rich
