overflow dripping
29 Aug 2011
Norfolk
The overflow pipe from the large cold water tank in the loft is dripping but only when the central heating is on. Any ideas what I need to do please?
The central heating time is a Randall 103 old clockwork type. The central heating and hot water are not seperate, so we have to have both on or nothing on.
I suspected as much. It's probably a matter of adjusting the maximum level in the cold tank so it stops filling an inch or so lower than currently.
I'm intrigued as to how the central heating being on affected the water level in the CWS :confused: Moreover, what did the make of the timer have to do with it all?
I'm intrigued as to how the central heating being on affected the water level in the CWS ?
Heating on, water in cylinder gets hot, expands, raises level in the tank feeding it.
I'm also intrigued about the timer question.
