I have a problem with the main tank in the loft, it appears to be dripping water out the overflow valve into the garden.
I was kinda hoping i could just get up and tighten a screw and be done with it.... Wishful thinking i know!
I came across the following link : http://www.diydoctor.org.uk/projects/cold_water tanks etc..htm
And in particular:
If an overflow pipe, either from your toilet cistern or from the roof tank, is dripping, and adjustment of the height of the ball arm does not cure the problem, the remedy will be to exchange one of the black rubber diaphragms, according to the valve you have, in the pictures and diagrams below. The water must be turned off and the operation is simple. The rubber diaphragms are available at most diy stores and plumbers merchants.
I could easily enough turn off the water, but what am i replacing it with - if i were to go to B&Q and ask for a rubber diaphragm i'd expect them to refer me to the local GUM clinic!
Any help much appreciated.
And in particular:
