Well I think it is an overflow pipe, anyway, my kitchen sink drain is leaking, but not under the sink. There is the normal drain pipe with a pipe coming off the side that goes into the wall. The water is leaking from within the wall and going under the kitchen and to the outside wall of the kitchen. My hubby thinks the main drain is clogged sending the water to the overflow in the wall, ( they did not have this pipe coming out of the roof like it is supposed to) but my thinking is if the drain is clogged it would come back up into the sink also. I believe that the overflow pipe is broken in the wall. The house is over 135 years old and who knows when those pipes were ever replaced. The minute you run water into sink the water just starts coming out the wall and flows freely in the sink. Comments please.
Thank you
ldyhwk89
Thank you
ldyhwk89
