Good Morning,
Ive got a blanco sink and an insinkerator food disposal system. Fitting them together for the normal waste was problem free, the instructions are spot on... the issue is for the sink overflow.
Blanco package the sink with the overflow for their own waste system (rightly so), but nothing comes with the insinkerator which allows a connection from the sink's overflow to either the insinkerator or more preferred option the u bend.
Blanco's kit has a piece which fits the back of the sink, and drops below the base, where a second piece would then attach to the drain at the bottom of the sink. The piece at the bottom is replaced so i can not use the provided blanco piece. The waste out on the insinkerator has a capped connector for the overflow which is where i would like to connect it, but cant seem to find any flexible pipes which would allow me to connect the two..
Any ideas on the type of pipe required? only need a piece approx 30cm long but ideally flexible.
