I am a bit Naive on this, and would appreciate any suggestion/ help on the below matter.
There is an overflow of water which goes out from the boiler.
When I turn the water supply on, in about 10 min the overflow starts, hence thinking the top water tank is full I switched of the water supply, then the overflow stops as expecetd.
Then when I try to open cold water from the tap, there is no cold water…..but i get hot water…which means top tank has no water…..
I am a bit confused as to how there can be overflow without the top tank being full? Where is the over flow from?
What could be the possible reason, ballvalve , thermostat?
