Overflowing water tank in attic
20 Jul 2008
Warwickshire
Just been outside the back door and have noticed a drip every 5 seconds from overflow pipe connected to the water tank in the attic.
What could be causing this ?
Thanks in advance.
Usually a failed ball valve but could be other problems eg failed cylinder coil of backflow
Check to see if the ball valve is dripping
Ps. Assuming you are not referring to the discharge pipe from an unvented hot water cylinder. In which case the problem needs to be investigated by an engineer with unvented qualification
Which water tank is it? There could be two, one that stores water and the other for the central heating.
A dripping overflow pipe, could be down to the the ball valve not closing, this could be that it has seized, require new washer or that there is debris in it that will not allow the valve to close, also it could be that the float height requires adjusting.
Then there is always a chance that you have water expanding through the vent pipe, this would require a little more investigation.
