Hi guys please help
I have a vokera unica 28 HE which I decided I wanted to add a Honeywell CMT927 wireless thermostat to which I did about a week ago and all worked fine.
However I decided I wanted to move the reciever box which required changing the wire. I dont think this is anything to do with the prob but am telling you just in case.
After doing this I put power back on but when I switched on Hot water tap boiler made strange gurgling noise nd locked out on code 20 (Limit thermostat fault/ fumes thermostat fault).
It wouldnt reset for ages but eventually did. But now when I switch on either hot water or central heating it makes noise again and the pressure gauge goes flying up towards 3bar so I quickly switch off. It then gradually drops down again to 1bar.
Any ideas? Why would the pressure go up so quick? Is it an air lock or something?
Please help thanks guys.
