Hi, first post so please be gentile !
5 years ago we moved in to our home, and withing weeks the old Wickes Bolier packed up. We got a guy in (it was just before christmas) and he quoted over £2K to rip out the old boiler and install a new one. Regretfully I was not around whilst the work was done and the job wasn't done very well (running pipework at ceiling level rather than under floors etc) - The system necer worked well and about three years ago I purchased an new pump, valve, HW cylinder, controller and room stats, and after consultation with a really nice plumber re-did the lot and moved a few rads at the same time.
Things were fine for 18 months or so and then the boiler wouldn't light and the plumber came and replaced the gas valve and all was fine up until now. The past few days I've notice that the rads were cold and I didn't hear the boiler clicking in and out. On inspection the overheat light was lit. Resetting the boiler worked for a few times, but now this fails. The following comments might help anyone come up with suggestions as to what needs to be replaced or checked.
1) - The pump still over-runs, and hot water can be felt advancing through the pipes until the boiler goes in to overheat
2) - Turning on the room stat activates the bolier on light, but on some occasions when the boiler has been on, the fan and other lights don't come on and the boiler fails to ignight.
3) - Reset the boiler and had the knob set to low settings had no affect - it still overheats
4) - Setting the pump to run faster (speed III) - still overheated.
Heating just HW or CH or both has no affect - it still overheats.
Suggestions welcome
Thanks,
Malcolm
Suggestions welcome
Thanks,
Malcolm
