Boiler (Yes its old) New World CH502
Natural gas
Thermo couple (with interupter)
Problem - once the hot water gets up to temperature, the overheat button clicks out, main burner and pilot goes out.
When left for a little while, if the overheat button is then reset, the pilot can be manually lit (and stays lit), if the boiler is then run (the water is of course already pretty hot) the main burners run for a short while and then above problem repeats.
As pilot remains lit intially-assume thermocouple ok.
Pump runs OK.
Pilot burn clean, no change in flame of late, flame touching top 25% of thermocouple.
Assumption (amateur)
- faulty thermostat is not turning off main burners when water temperature setting reached - causing overheat.
- faulty overheat switch, triggering in error.
- Gas valve faulty not being switched off by thermostat causing overheat.
Questions
1)In laymans terms, is it possible to do DIY tests to acertain which of above may be the problem ?
2)Any other likely causes ?
Thanks in advance for the help.
Regards Graham
Natural gas
Pump runs OK.
Questions
Regards Graham
