As the title suggests I have a overheating Linea 735.
The problem is on heating and hot water. 18month old boiler, system flushed, magnaclean filter fitted.
The overheating noise is not a constant squealing, more like a motion noise, hard to explain, like a steam train engine, noise/quiet/noise quiet/noise/quiet. The noise lasts about 0.5secs, then quiet 0.5secs,noise 0.5secs etc.
It's not the plate HX as when you run the hot water until the noise occurs and quickly shut off the cold inlet the temp display does not show an excessive temperature.
The noise seems to appear over 60degC. Modulation of gas valve ok.
Any thoughts???
Any thoughts???
