boiler: Worcester 240 combi RSF (about 2/3 years old)
All of a sudden our boiler wouldn't fire up for either the heating or hot water. It made the noises indicating that it may light any minute, but the pilot light just never sparked. After a little reading I discovered that it may have automatically switched itself off due to overheating, so I pressed the reset switch and hey-presto it fired up ok. However, after a few minutes it switched itself off again and the reset switch popped out.
I've tried turning the thermostat right down to minimum, but both the hot water and radiators get very very hot. A very tiny amount of water is also dripping from the bottom of the boiler. The boiler also sometimes made a screeching noise (i guess the pump?) - could this have contributed to it's failure?
The pressure on the gauge is just over 1 bar.
Can anyone suggest possible causes/solutions (if there are any!)?
thanks very much
thanks very much
