overheating
3 Aug 2008
Cardiff
on a open vent'heat only boiler if the boiler flow temp is considerably higher then the return and boiler overheats then this can only be dry system, pump knackered,airlocks??
what would be the symthoms of airlocks in central heat system ? overheating preceded by loud noises in pipework?ta
EH .... main boiler stat gone and allowing too much heat into the boiler
