AS above, but might be worth spending a bit of time on the following.
1. Take the thermostat out and refill with water, watch for overheating. Ensure the system is completely full of water and has no air locks especially in the heater (loosen small water pipes from engine to passenger compartment until you see water coming).
2. As the temperature rises watch and listen for the electric fan on the radiator to come on. If temp rises and no fan investigate.
If you still have problems with no thermostat fitted and the fan working, then look at the head gasket. But in my limited experience the gasket will cause violent bubbles in the cooling system and or oil/coolant contamination along with overheating.
So do all the easy stuff first
