Around three years ago I decided to do some improvements in my bathroom which involved removing an old concrete and brick cupboard which was in my kitchen but protruded into my bathroom.
It had concrete floor and a concrete shelf which I guess was for the storage of coal a lot of years ago.
The opening was in the kitchen and the load bearing walls in the bathroom like an L shape.
After propping up the walls and removing walls and brick round opening I bricked up old door opening so beam had something to sit on at kitchen side.
I will have one large beam running width of bathroom from kitchen wall to bedroom wall and another smaller beam sitting on top of this beam and sitting in cavity wall to replace the L shaped walls.
I have three padstones 300mm long and 100mm wide cut into these walls for beams to sit on.
Initial plan was to get job done by a builder but I got laid off and job has been delayed so long building warrants have ran out and I cant seem to locate the engineer and now only have the cash to do it myself.
Everything is going great and am ready to order and fit beams but on the plans I had done it gives length of beams but I think the guy may have made an error as he only allows for 10mm each side for beams to sit on padstones.
Is this enough to support beams or should I make them the full width of the padstones 100mm or would this cause problems.
It also states that ends are to be packed with slate and hard pack cement to help spread load, is this on padstone under beam or around the beam.
Sorry if this is to much info. but this seems like a bit I should get exactly right before kids go for a bath under this. lol.
This may also seem silly but beams are to be galvanised and encased in fireproof gyproc, do I just wedge bits of wood inside beams to secure gyroc or is there a better method.
So close to saving myself a fortune here it would be a travesty to have to rip it all out again.
