Hi, sorry if I am posting in the wrong place.
I am trying to help my brother get the right paint for his walls. He tested them by putting methylated spirits on a cloth then rubbing it on the wall. No paint came off, I believe this means the paint on his walls is oil/solvent based.
Should a solvent based undercoat be used? Is this the same as a solvent based primer or is this a separate item? If he does indeed use a solvent based undercoat, which type of top coat does he use and is the top coat the colour you want to put on the walls?
Many thanks
Many thanks
