Been having a lot of problems with my Central heating recently. Started when I replaced a bathroom radiator and when I refilled the system some of the radiators would not get hot. Called a plumber who diagnosed a powerflush was required. £450 later I still had three cold radiators. After a row with the plumber who said it was my fault because I must have disturbed some muck when I drained down first time, I eventually got all the rads working by removing them, hosing them through and then turning them on one by one. Only problem is now the system is overpumping even when the pump is on it's lowest setting. The vent pipe is at least 4ft above the header tank before it comes back down. The pump has been replaced and the pipework layout is (coming from the pump upwards) first the cold water feed which is about 4 inches from the pump and then the vent pipe another couple of inches further on. The plumber (just about on speaking terms) says it's probably a partially blocked manifold and he will charge £50 an hour to find it and then clean it out/replace it. Does this sound sensible or should I be looking at something else? The heating and hot water are working ok but I am worried that if it's not sorted The system will be corroding from the inside.
