HI,
I have fitted a P shape bath and pivot screen, when I open the door the rubber seal lifts and forms a gap and then water runs over the side. the fixing bracket is fixed tight to the bath. How can I stop this from happening
when I have had a shower, I open the screen afterwards to clean it, then the next time I use the shower the seal has lifted slightly and that's when the water escapes between the seal and the bath
