Hi
I have an issue with my toilet where water is leaking into the toilet plan. I opened up the cistern and it has a Pacific flush valve similar to this picture
There are no external leaks between the pan and cistern and the water only starts to leak when the water level reaches the holes near the bottom of the flush valve assembly so the problem has something to do with the large rubber doughnut shaped ring that's attached to the blue part.
Anyone know where I can get a replacement rubber washer without having to replace the whole valve? If its not possible to get the rubber seal, which replacement flush valves can I get that are easy to fit without having to take the cistern off?
Thanks in advance
Rob
Thanks in advance
Rob
