Pad & Beam Footings
5 May 2012
London
Hi everyone,
I am having a rear extension built and because of sewers in the garden the architect specifield pad & beam footings and had a structural engineer draw up the calculations. The engineer has drawn up the specs for the pads and described the beams which are 203x102x23UB RSJ's
Am I right in saying that the RSJ width is 102mm ??
If this is the case is this large enough to build the rear and side wall for the extension off of??
Thanks in advance for any help.
Yes.
Well, width wise, you'll be putting 100mm blocks or simillar width bricks onto them, so no problems there...
If you are asking whether or not they'll take the load of walls, roofs, and floors, I would hope that your SE has designed them correctly, but no way of knowing without a lot more information.
Presumably there will be two beams side by side - for the inner and outer leaf of the cavity wall
Thanks for the replies.
I must apologise as I have read something wrong, the RSJ's are actually 203x102x23 UC not UB.
there is only three beams specified of the above size and the extension is specified as cavity walls. It's just baffling me a bit lol.
Are you sure? 203 x 102 is a UB. 203mm UCs are also approx 203mm wide...
Maybe it's a 203 UC encased in concrete? You'd be able to sit a cavity wall on that.
That is a beam dimension, not a column - columns are normally square
I would get the engineer to clarify, as if he has only specified one beam per elevation it may well be a column
Something tells me it's a typo on the paperwork but it is worrying me, especially as the build is starting in a weeks time lol.
Gonna have to gt it clarified but what you said about it being 203x203 sounds like more sense to me.
