Ok ,hope you can answer this for me please .
Sanded down skirting and window board in bedroom prior to redecorating /papering room .
After sanding down the wood (previously been glossed 15 years or so ago probably )I applied two coats of undercoat /primer .Sanded again ready for glossing .
Apllied the gloss and got a strange finish ,which looks like lots of little pools within the paint .Thought I would give it another coat which may get rid of the imperfections .Started to look OK ,then as it dried a bit it started cracking /creasing up .But only at one end of the windowboard and a small section of the skirting on the other side of the room .
Now I have been cleaning brush in whitespirit,then washing up liquid to clean off the white spirit in between coats .Rinsing with lots of water .
I have also used the same brush to paint matt ceiling paint on the plaster coving in between glossing and washing brush in water only.
Can anybody explain whats going wrong .?
I will have to sand down again ,but I dont want to turn this job into the Forth Bridge of painting jobs .!!
Many Thanks for your help .
Regards
Rob.
Regards
Rob.
