Hi
I've just painted the new tyrolean I have had done following an extension at the side of the house.
I'm using Dulux Weathershield Smooth Masonry Paint. 1st coat was diluted 5 parts paint 1 part water as per instructions on tin. I've then applied a further 2 normal coats. However, as the paint dries it appears to be crazing in areas - you can only see it when you get to about within 1ft of it. I've put the paint on as thinly as possible to prevent paint gathering in the valleys of the tyrolean.
As it can only be seen close up, I can probably live with the appearance, but need to know whether or not this could cause a problem in the future with the rain penetrating wall? Or as I have done 3 coats, would each coat have covered the crazing below?
