I have some really ugly window putty work on the outside of a window which I cannot reach to alter ... when viewed from within the room (i.e. looking out of the window) it looks bad. So, when I painted the inside of the window this week I painted into the glass with the paint about 1cm and it covered everything up nicely. Basically, it has formed a sharp white border at the edge of the glass.
Trouble is, the paint has formed a film that comes loose very easily and was easily damaged when the window was cleaned this morning. I applied:
2 coats of Zinsser BIN which the manufacturer claims will adhere well to glass (this has NOT been my experience ... it adheres but also comes right off with great ease ... by no means a solid solution to painting glass)
2 coats of Dulux Trade High Gloss on top of the BIN.
I didn't use a gloss undercoat under the gloss, but the undercoat would not solve this problem, because the BIN itself is coming off the glass easily, and BIN is supposed to adhere to glass better than gloss undercoat anyway.
It is clear that this film is not going to last long. Is there any other paint I can use that will firmly stick to the glass for a long-lasting solution? Or, in other words, what is the best paint to use to get a solid opaque colour on to glass? [Spraying is *not* an option]
Thanks.
Thanks.
