It has been a while (about 10 years) since I had to do any exterior metal paintwork - and I am looking for some advice.
We have a Garador Garage door which still has on it the original black paint applied at the factory and is about 3 years old.
We decided we wanted to change the colour to match our front door which we are going to re-paint (not yet done).
To get the colour we wanted we bought a Valspar Exterior Metal and Wood Gloss Paint in the mixed colour from B&Q just before the current lock-down.
On the tin is simply says that the existing paintwork should be sanded down before application - which we did. No mention of primer or undercoat except for new untrated metalwork.
However, once applied (to a test area which had been sanded) and dry I find that I can scratch the new paint off completely and easily with my fingernail - the new paint seems to have covered but not adhered to the old paint.
My question is - is this a possible problem with the original paint used by Garador, or is it a problem with the Valspar paint (which I assume is water based as it says brushes should be cleaned in warm water), or is it likely to be a compatibility problem between the two.
Any thoughts would be appreciated.
