Paint not quite adhering to some areas of plaster
23 Mar 2007
Cheshire
The walls in a room were replastered about five weeks ago and a couple of days ago, I started to paint them with watered-down emulsion. There are some patches of plaster that have been more difficult to paint than others, in that they haven't accepted the paint as readily as the majority of the surface. With successive coats, the hard-to-paint areas are becoming whiter, however, there is one patch in particular which has accepted next-to-no paint, and is pictured below.
How can I determine whether the wall is damp at this location? I will look outside tomorrow, to see if there is obvious damage to the wall at or above that location. Is there any other probably cause, other than damp?
In this thread, I raised the issue of slighlty darker patches of plaster in some areas and indeed, at least one particular darker area on the ceiling was more resistant to paint than surrounding areas, although I'm not sure if any correlation exists between darkness and preparedness to accept paint. You can see an area on the ceiling which is darker. Attempts to photograph after painting showed no difference, although it is clear enough the eye.
It could be that the plaster has been over polished,, that can make painting difficult. If you can establish that you dont have a damp problem, paint over that two areas of wall, with white oil based undercoat, (smelly stuff). Paint them from top to bottom, just on the front of the walls, cutting in neatly at the internal corners. "Let that dry", then emulsion over them, couple of coats, as per usual,,, that'll sort it out.
Okay, great.; thanks for the advice. To help determine whether or not it's damp, in case I can't see external damage, can I hold some toilet tissue against the wall and see if it becomes damp, or would that not work?
Get a damp detector.
I'd never leave home without one and you can get a cheap one for £5.79 on ebay.
No point in guessing and wondering and making mistakes and worrying.
