The waterbased paint is still wet? I have never encountered that.
The first time that I encountered MS polymers such as CT1, they had been used by the sash window restorer. I applied oil based paint directly over it- it stayed tacky for days. I hit it with a coat of waterbased undercoat and it was fine the next day.
Another job, I used CT1 to fill the gaps between a customer's floor and skirting. A year later I went back to decorate. I had forgotten that I had used CT1 and applied a coat of oil based eggshell to the skirting. It stayed tacky until I hit it with waterbased paint.
I recently come across a team of decorators that tried to paint over CT1 a couple of hours after applying it. They used waterbased paints. The paint dried, but crazed. I did try explaining that they need to wait until the next day, but it got lost in translation.
CTI is use around windows or along skirting sometimes. Paint should not be wet? What sort of paint? Was it gloss or emulsion. If gloss was it acrylic or alkid?
Try some clear water based varnish over the CT1. Presumably, there must be something in the furniture paint that the CT1 doesn't like. Once the varnish has cured, further coats of the furniture paint should be fine.
