paint removal
10 Oct 2004
Manchester
My father in law has just had the outside of his house painted. Unfortunately, during the painting, his metallic green car has become speckled with magnolia masonry paint.
Does anybody have any suggestions on how best to remove this?
I have contemplated:
1. T-Cut and a polishing sponge/bonnet mounted to an angle grinder (used very carefully) on the basis that the paint specks will be softer than the baked on car paintwork.
2. Very careful use of very fine wet and dry - used wet with washing up liquid to make less abrasive.
3. Try some fly remover type solvent to soften the paint.
Any suggestions will be gratefully received.
Cheers.
Steve.
Use G-3 Compound paste, Wet the panel (or area to be worked on) and rub the paste into it. A little bit goes a long way! A small tube will do a car and a half!
Get it from a paint supplier like martin browns.
