Paint stripping chemical
16 May 2011
I am trying to remove the paint from my garden wall. I did try a non hazardous gel chemical, that can be used also inside, nothing. I then tried another gel chemical, called Paint Panther. After two applications I managed to remove some paint with a wire brush and hard work but still non a clear wall.
Can anyone recommend any other efficient chemical paint stripper that can remove exterior masonry paint?
I did not try jet spray. The problem is that the pait does not get soft enough and does not peeling away at all.
Basically my question would be; has anyone used a paint stripping chemical with success in removing exterior masonry paint?
