Please recommend an effective paint stripper for wooden interior door frames. Any tips would be appreciated to produce a smooth finish. Would frame need to be primed b4 painting gloss. Tnx
"....In older properties, in the UK, earlier than about the late 1960's, added care must be taken if there is a chance that you are stripping lead based paint - avoid mechanical and heat methods of stripping (these could produce lead dust or fumes) and wear an appropriate breathing mask. Seek guidance to ensure the health of you and your family is not effected..."
Don't do either of those. For perfect results, sand them back until they are smooth and then undercoat and topcoat. Satinwood is much better than gloss.
